Carb nitrous kit on Ls1?
Old May 6, 2011 | 09:25 PM
blow thru's Avatar
Default Carb nitrous kit on Ls1?
G- Day guys i have a nitrous kit off my old smallblock and now wanting to put a kit on my LS1 with nos fogger tip,now can i use my solinoids from that kit?Im not sure if the fuel solinoid is the same as a high pressure efi one.Also could i use this kit and operate as a low pressure with its own holley blue pump and standalone fuel system with a holley reg set at 6 psi with E85 in the tank?I plan on spraying 100 shot and car will have a maffless tune with all the usual boltons.
cheers
Glenn
Old May 8, 2011 | 03:59 AM
blow thru's Avatar
cheers
Glenn
found all the answers i needed..
