Micro Edge and MSD 8733 LS-2 Step question
Old May 15, 2011 | 09:54 AM
Tripdagoat's Avatar
Default Micro Edge and MSD 8733 LS-2 Step question
My question is how (if possible) can I wire my system to use both my 2 step and my Micro Edge, I want to launch my car at 4500, but the issue I see is if my Micro Edge is activated the criteria for spraying is met when I put my pedal to the floor and my rev exceeds the 3000 rpm window. Anyone else run into this problem, and if so what was your work around for it. I want there to be no way possible for the nitrous to activate by mistake(I know you can set it for 2nd gear only, but if the rpm drops and it thinks i shifted there might be a problem with it activating). The last thing I want to experiment with is adding nitrous when the rev limiter is on, probably catastrophic.
Old May 16, 2011 | 01:52 PM
1904gto's Avatar
wire the two step in like a trans brake
Old May 16, 2011 | 02:42 PM
nyg215's Avatar
wire it in per the directions and set up your controller for first gear lockout....it works....thats how mine is setup
