NOS 15982 window switch wiring help
Old May 18, 2011 | 05:29 PM
blow thru's Avatar
Default NOS 15982 window switch wiring help
Hi guys i just purchased a nos 15982 wot/rpm window switch and i have a 03 LS1 now im in the middle of wiring up my kit and the diagrams on the NOS website talk about wot signal off the tps,now im running a micro switch.Does anyone please have a diagram?Any help would be appreciated
cheers
Old May 19, 2011 | 05:53 PM
Chris@NitroDaves
Guest
Posts: n/a
http://holley.com/data/Products/Tech...R10482rev4.pdf
" The throttle position sensor input does NOT have to be used. If this input is not used and is to be disabled, connect the TPS input wire (from the NOS WOT/Window Switch) to a good chassis ground. Select “falling” TPS in the configuration and set value to 4.0. "
As far as a diagram I don't have anything like that for you unfortunately.
Old May 20, 2011 | 01:27 AM
blow thru's Avatar
Ok sweet thanks very much for that.
