02 Z06 with 150 shot jetting question
.... I noticed it was running really rich. What would you suggest? I currently have the suggested jets for 150- n62 f38. should i drop the fuel to 35 or 33?i attached the dyno graph...the top run is NA, the middle is 150shot and the bottom is 100shot.
I just use the *** dyno and data log. I also run known dyno'd vettes and see where I sit. I've beat 620rwhp SC'd C5s so I'd say I'm getting a good portion of my jetting out of it.
Yes car is running great. Having an issue with my NGK AFX wideband with the NTK sensor. At WOT it reads as low as 11.3 AFR. The LC-1 I just removed and 2 different Dynos showed 12.8-9 at WOT. Can the bosch sensors be that far off or is the NGK wrong? Narrow-bands were in the 960s to 980s at the same time the NGK was at 11.6. The NGK is suppose to be the best consumer grade unit but...
So I gotta figure that out.
