BR6EF PLUGS FOR 125 shot
Old Jun 23, 2011 | 11:56 PM
mean98camz28's Avatar
Default BR6EF PLUGS FOR 125 shot
Just like the title says I got my plugs in today they are br6ef and I galled them at 35. But one question real quick if we can use this plugs why are they not pulled up under our car. They pulled Up under jauger. Ok to get back now I have some basic molds like lid elbow lt header ory slp ld. Will this plugs work good bc it was wat I found on here to use.
Please tell fast if I have return them or not.
And one more thing. I'm having trouble finding a 12 volt key source for my switches. Can I just run the power to the acc post my the fuse box in the engine bay
Old Jun 24, 2011 | 07:26 AM
Canbarelygo's Avatar
hell id use em i was sprayin 100 on tr6's on the out of the box gap.
Old Jun 24, 2011 | 08:56 AM
Graham@NitrousOutlet
Guest
Posts: n/a
If you are going to spray over 100hp I would go ahead and get the br7ef. No reason not to. Gap them as well at .35.
They are not pulled up under our car because they are not a stock plug. Autozone doesn't do as much nitrous research as we go.
You do have the correct plug for your car. Just not quite cold enough for what you are looking at doing.
Old Jun 25, 2011 | 03:03 PM
Can someone please answer the other part of question please.
Where is the right choice to put my switch 12 volt key source and I have them wired together.
