Easy question...
Old Jul 23, 2011 | 06:40 PM
BPG's Avatar
BPG
Default Easy question...
What is the blue fitting size that screws into the N2O solenoid between the feed line from the bottle, to the noid? I cross threaded it while moving the noids around... and now its leaking like crazy. Its on a HSW Sudden Impact kit if that matters at all... so whatever the stock size it...
Old Jul 23, 2011 | 09:24 PM
krissoto's Avatar
the fitting that screws into the noid, should be 1/8" pipe, and depending on the size of feed line, could be 3an/4an.
Old Jul 23, 2011 | 09:34 PM
BPG's Avatar
BPG
Thanks. Its the "stock" feed line... should be 4an, no?
Old Jul 23, 2011 | 09:42 PM
krissoto's Avatar
Some are diff, I believe on my HSW kit, the fitting on the plate is a 3 an
Old Jul 25, 2011 | 09:47 AM
Graham@NitrousOutlet
Guest
Posts: n/a
The inlet fitting on the solenoid, what connects the mainfeed line to the nitrous solenoid is going to be 1/4NPT x 4an on that system I think.
Old Jul 26, 2011 | 01:42 AM
BPG's Avatar
BPG
thanks, graham. i just said screw it...and bought one of every fitting i thought it "might" be....
Old Jul 26, 2011 | 08:52 AM
Guest
Posts: n/a
Nothing succeeds like excess.
