Microedge + with LNC-002
Old Jul 25, 2011 | 09:05 AM
tigertales's Avatar
Default Microedge + with LNC-002
I have the Microedge +, which is a progressive N2O controller.
I also plan to use the LNC-002 to pull timing from my tune rather than upload a tune just to spray.
How do wire the LNC-002 to only pull timing when spraying?
The progressive will be pulsing to solenoids, so this is probably not a good place to wire the LNC-002??
Thanks for the help.
Old Jul 25, 2011 | 02:05 PM
Graham@NitrousOutlet
Guest
Posts: n/a
The LNC needs to be wired to the relay that arms the solenoids. This will turn it on when the "arm" switch is on.
Old Jul 25, 2011 | 05:03 PM
tigertales's Avatar
Thanks. I'm thinking that I will use the second stage of the microedge + to do this properly.
