Mallory 685 help please
Old Jul 30, 2011 | 10:11 AM
lncboytre_d's Avatar
Default Mallory 685 help please
I hook the box up today using the MSD adapter harness, I am 99.7% sure that the box is installed correctly, yet the car won't start. I disconnect the box and she fires right up. I reconnect the box....nothing. I leave the box connected and use the bypass harness and she fires up. The start retard is set at .01, I have played with it all the way up to 10* of start retard. What am I missing?
Old Jul 30, 2011 | 06:25 PM
Speed Density's Avatar
hashtagBMW
You sure the box works?
Old Jul 30, 2011 | 07:34 PM
I just received the box from summit, it wouldn't be the first time I received a bad ignition part. I think I'm going to send it back come monday. I've tried fooling with it half the day still no luck.
Old Jul 30, 2011 | 10:46 PM
WhitePhoenix99's Avatar
Make sure all of your connections are good..
Old Jul 31, 2011 | 10:02 AM
I'll send the box back tuesday, but before I do I'm going to pull all the wires and start from the begining.
Old Jul 31, 2011 | 01:59 PM
Ok, I took all the wires out and rewired it on wire at a time.....still no start. I use the bypass harness from the box and bam, fires right up. Box is going back.
