Tuning for nitrous.
Old Aug 2, 2011 | 10:55 AM
Kev SS's Avatar
Default Tuning for nitrous.
I plan on getting a wet plate kit here soon.
This my whole setup up.
bolt on car that runs 8.5 flat on the 1/8th mile in crappy weather and I already have drag radials...Im hoping my 3800 stall will drop me into the 7.9 area..but I may want to go a little quicker.
I'm wanting idealy to get a wet plate kit, mount the bottle in between the rear seats (easy access), purge kit, bottle warmer, and I'm only wanting to go 100 or 125 shot.
I have been told that I wouldn't need to pull time from the car...Like I said if the stall get's me into the 7's then I will prolly not use the spray much...maybe just 1 weekend a month if that.
So would I need to pull timinng with just 125 shot on a wet kit?
Old Aug 2, 2011 | 11:12 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Wanna Bet?
Who tunes the vehicle?
Chances are yes, some timing will need to be pulled.
Old Aug 2, 2011 | 11:16 AM
Kev SS's Avatar
A friend of mine has HP tuner software, He tunes most of the ls1 cars around here.
Old Aug 2, 2011 | 11:35 AM
Guest
Posts: n/a
Ask him. It depends on how aggressive the motor tune is as well. But chances are that you will. I would pull the timing, read the plugs, and see if you can add any back.
Old Aug 2, 2011 | 03:52 PM
Doug G's Avatar
LOL...right They don't call it giggle gas for nothing.
After the first hit,you'll want more
Old Aug 2, 2011 | 04:06 PM
87silverbullet's Avatar
Originally Posted by Graham@NitrousOutlet
Wanna Bet?
Yeah, and then there will be a thread "I want to spray a 175 shot"
To the OP-make sure you also have a non projected tip plug in the motor when spraying.
