Line size for shot amounts.
Old Aug 9, 2011 | 08:16 AM
Marcello7x's Avatar
Default Line size for shot amounts.
Is there a chart anywhere on min line size, in -an for example, on how much of a shot it can support.
I have a kit in my basement that was for a 150 shot, but im looking to go with 200 or more and want to know if my lines will suffice or if i need to buy new ones.
Old Aug 9, 2011 | 09:05 AM
Graham@NitrousOutlet
Guest
Posts: n/a
As far as a main feel line you will need a 4an for that power level.
Old Aug 9, 2011 | 01:53 PM
Marcello7x's Avatar
How big could i go with the -4an if i decide to go bigger?
Old Aug 9, 2011 | 01:58 PM
brett walker's Avatar
Id say 225. Anything over that id recommend going to a -6
Hope this helps
Old Aug 9, 2011 | 02:24 PM
Guest
Posts: n/a
You can safely spray 250hp on a 4an. But at that power level you will see increased flow from a 6an line.
Old Aug 9, 2011 | 04:31 PM
Chris@NitroDaves
Guest
Posts: n/a
My personal preference would be to go with a 6an line for anything over 225hp but you can get away with it a 250hp.
Old Aug 9, 2011 | 05:17 PM
Carter01's Avatar
-4 lasted me up to 250 with no problems. Spraying 300 now so i went to a -6. FWIW
Old Aug 9, 2011 | 07:46 PM
ATVracr's Avatar
-8an over 500.
Old Aug 10, 2011 | 10:18 AM
Guest
Posts: n/a
Originally Posted by ATVracr
-8an over 500.
Show off.
Old Aug 10, 2011 | 11:03 AM
Marcello7x's Avatar
-8an over 500.
Do you refill the bottle after every run????
Depending on the line i already, which i hope is -4an, i'll run a 125-150 first stage followed by 100.
Otherwise i'll order some -6an and run dual 150's
Old Aug 10, 2011 | 11:10 AM
Guest
Posts: n/a
500hp is probably around 3.1-3.3 lbs of nitrous for ATV's car in the 1/4.
Old Aug 10, 2011 | 12:09 PM
ATVracr's Avatar
No, but I do change it after every run if we are 1/4 mile racing.
15lb bottle also.
Old Aug 10, 2011 | 12:11 PM
ATVracr's Avatar
Originally Posted by Graham@NitrousOutlet
Show off.
We still have a 6an line in the car, I was just saying. LOL !
Old Aug 10, 2011 | 12:45 PM
Oldass's Avatar
ATVracer, how many bottles do you take to a race?
Old Aug 10, 2011 | 01:13 PM
ATVracr's Avatar
5-6 depending on the race, sometimes we take the mother bottle and refill them at nite.
Old Aug 10, 2011 | 02:11 PM
ShiznityZ28's Avatar
yes but its only 3 lbs or so used . but for consistancy and in our very competative class we don't like to make to many double hits on 1 bottle and never in elims. why risk the .05 or so and lose? we keep enough bottles and will sometimes double hit in qual if were already in the show. and if its more than a quick 8 we will take the fill setup and top the qual bottles off in case we go to the finals.
Old Aug 10, 2011 | 02:46 PM
ATVracr's Avatar
3lbs on the run but prolly 5lbs or more total for a run once you open the line, purge it and close the line.
Old Aug 11, 2011 | 07:18 AM
Marcello7x's Avatar
DAMNNN...enough said
