how big a shot b4 lifting heads?
Old Aug 12, 2011 | 08:55 AM
mattz06's Avatar
Default how big a shot b4 lifting heads?
lsx block, wiseco pistons, (bottom end can take it) ls7 heads with arp studs, currently running a 300 shot, thinking about putting it on a 400 shot. will ls7 heads/arp bolts/gm gaskets hold it? obviously will have proper tune... whats everyone finding is pushing the limit?
maybe I should wait to do 6 bolt heads...
Old Aug 12, 2011 | 09:29 AM
Graham@NitrousOutlet
Guest
Posts: n/a
With a proper tune no reason you can not do 400hp.
You will not find many here hitting that amount.
Old Aug 12, 2011 | 10:44 AM
ShiznityZ28's Avatar
size of shot is not the problem for lifting heads. to much timing/ bad tune is. i don't believe you can get enough nitrous into the stock heads to lift them without an improper tune. JMHO.
Old Aug 12, 2011 | 02:03 PM
Carter01's Avatar
Nice! That's what i like to hear!
Old Aug 12, 2011 | 03:00 PM
FlashWS6's Avatar
Destroyer of Exotics
4 bolt heads here, no issues with that size shot on a nitrous outlet plate kit!
Old Aug 12, 2011 | 04:30 PM
Chris@NitroDaves
Guest
Posts: n/a
I knew you would like that post....
Old Aug 13, 2011 | 10:24 AM
Carter01's Avatar
hahaha, you know me too well..... what are 400 jets again? jk.......
Old Aug 13, 2011 | 11:38 AM
Cold Zero's Avatar
Originally Posted by carter01
hahaha, you know me too well..... What are 400 jets again?:d jk.......
omg ..
Old Aug 13, 2011 | 01:55 PM
ls2 bait's Avatar
Agreed with shiz. Ive lifted heads with a 150 shot abd cometic gaskets with too much timing. Now running a 250 and gm gaskets for 2 yrs without a hiccup. And there is prob some wiggle room in my tune.
Old Aug 14, 2011 | 03:36 PM
dnkynrbk's Avatar
With the right tune,plugs and also Just head stud your motor and that will help alot
