another msd window switch thread
Old Aug 19, 2011 | 06:33 PM
runnin13s's Avatar
Default another msd window switch thread
ok I have the MSD distributorless window switch part number 89561
Here is my problem. I have it all wired up white wire to the tach signal etc. there is a single grey "loop" wire. i have cut. With the wire cut the window switch does not work at all... when i reconnect the wires the window switch will work but it activates and deactivates at exactly half of what the pills are set at,
from what i read by cutting the loop it should bring the switch to work properly the v8 motor and it work correctly but it obviously is not.
Old Aug 23, 2011 | 04:01 PM
runnin13s's Avatar
any help?
Old Aug 23, 2011 | 04:20 PM
Graham@NitrousOutlet
Guest
Posts: n/a
Where are you pulling tach signal from?
Old Aug 24, 2011 | 02:30 PM
runnin13s's Avatar
the number 10 pin white wire.
Old Aug 24, 2011 | 08:49 PM
1lejohn's Avatar
Not sure about that sw. but my digi MSD sw. had to be set on 4cylinder mode for it to work at the correct rpm.
Old Aug 28, 2011 | 05:15 PM
Black99TransAm's Avatar
Yup has to be set on 4 cyl to work...
