Is a 150 ok?
Old Sep 7, 2011 | 11:20 AM
andys02r1's Avatar
Default Is a 150 ok?
I got a 2000 camaro cam only. Its got stock 28 pound injectors and a 255 pump. Ive got a nitrous outlet plate kit on the way. Just wondering if a 150 shot would be alright on those injectors? If not what shot would be alright?
Old Sep 7, 2011 | 02:14 PM
blackls1ta00's Avatar
the other nitrous guys wud know more than me, but i personally wud go with a bigger injector for more nitrous use in the future like at least a 30lb and start with a 100 shot and tr6 plugs.and those stock injectors shud be 26lb for a 2000,the 01 & 02 had the 28s.
Old Sep 7, 2011 | 02:22 PM
WheelsUp84z's Avatar
If its a wet shot its not the injector you need to worry about, its the fuel pump. Carter is up to 330ish (advertised) shot on stock injectors and a 255lph pump.
Old Sep 7, 2011 | 02:26 PM
BigBirdLS1's Avatar
If you spray the 150 shot are you planning on getting it tuned for the nitrous. I see you are cam only and I've got a pretty good idea that the tuner raised the timing some to make more hp plus most if not all cams have timing ground into them. It may be a good idea to get some sort of device to pull timing when you want to spray it or just have your tuner give your ride a "nitrous tune"
