Need help with injectors?
Old Sep 18, 2011 | 01:00 AM
karpetcm's Avatar
Default Need help with injectors?
Im running a 100 shot dry and to keep it safe i want to upgrade to the injectors in the link below. I know its 30lbs but there Ford Injectors and trying to see if that is sufficient enough to run with a re tune for 150 shot dry. I now i would still have to check duty cycle but what are your experiences or advice, thanks in advance.http://cgi.ebay.com/ebaymotors/30lb-...item415d4f24f7
Old Sep 18, 2011 | 02:32 AM
batboy's Avatar
Those injectors should be fine for a 100 shot. You'll probably need the 42# green tops for a 150 shot. I found it's really hard trying to tune for larger than a 100 shot of dry. I ended up going to a wet system.
Old Sep 18, 2011 | 11:33 AM
karpetcm's Avatar
Im starting to slowly figure that out on these dry systems. Im probably just going to upgrade the injectors and do a 125-150 dry shot after checking a/f and duty cycle and leave it at that. Hard to find a shop in my neighborhood to just check duty cycles without having to try to convince me buying other stuff or other services.
