New motor...base timing to start with?
Old Oct 2, 2011 | 09:53 PM
ZTwentyAteU's Avatar
Default New motor...base timing to start with?
I spit a rod at ls fest and i've had to build a new motor, Mast headed 408 now (was stock ci lq9). I was already running a "lot" of timing, 22! degrees on a n20 outlet plate with a .078. Timing isnt why the old motor let go, it just had too many high rpm passes on it over several years. I want to start soft on the new motor and maybe add a little. Is 15 a good starting point yall think? I'm thinking 18 is plenty, i'm not gona run her on the edge anymore. I know I know, read plugs..but I need to start conservative so I can get a reading first! Where's ATVracer? BTW i'm on vp113 so its a little different, but a lot like running c16 on tuneup
Old Oct 3, 2011 | 07:45 AM
soundengineer's Avatar
Need more motor info to get you in the ball park...
Compression?
Heads?
Intake?
Then I can probably give you a close guess to play it safe
You know how to reach me
Old Oct 3, 2011 | 10:21 AM
ShiznityZ28's Avatar
15 should be fine (guessing 11.0 or so and same jet) more info would be geat. engine compression, Compression height, cam specs, what mast head etc.
Old Oct 3, 2011 | 07:56 PM
thedudeZ's Avatar
Hell, why not see what it runs a few passes on motor before you start beating on it?
Old Oct 3, 2011 | 08:00 PM
SSPerformance's Avatar
Same compression?
Old Oct 4, 2011 | 11:13 AM
^ Wes i'm gona tune it on motor first of course hahaha.
Old Oct 4, 2011 | 11:26 PM
I have not calculated compression...come to think of it, I never did on the old setup.
I have the 6bolt small bore mast heads. 70cc chamber, .041 gasket, -4cc piston
old setup was 62cc head, -11cc piston
cam is 25x 25x .629/.613 108+4
