A odd question....
Old Oct 6, 2011 | 02:16 PM
Kev SS's Avatar
Default A odd question....
I currently have a tnt f-2 kit I will be installing this evening...I don't have a window switch...I was wondering...and I've seen this done once...coudn't i hold the wot switch in my hand and just hit it after 3rpms to prevent shooting it too low?
Old Oct 6, 2011 | 04:52 PM
custm2500's Avatar
Ph.D. in HUBRIS
You want the WOT switch on the throttle. It confirms you are at 100% throttle. In addition you need an arming switch. Not sure if you used the wrong name or intended to not install a WOT and only run one arming switch. That would be a very bad idea.
You can have a arming switch that you hold in your hand/ mount where you can reach it.
