Progressive wet shot?s
Old Oct 11, 2011 | 12:33 PM
LSWONGTO's Avatar
Default Progressive wet shot?s
So how does it progressively ramp up the nitrous? I am looking to spray a 100 wet shot on top of the blower for lower Iats & moar powa obviously. But I only want around a 50 shot in 2nd to come on slowly and a 100 shot in 3rd & 4th coming on alittle slowly in 3rd to aid with traction. Is this doable? Any recommendations for a good progressive controller? Thanks for any help. J-Wins
Old Oct 11, 2011 | 04:07 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
a progressive controller controls the nitrous flow by pulsing the solenoid and restricting the flow by how long the solenoid is open.
we have the maximizer 3 controller that you can program on a timer, not programmable by gear though currently
Old Oct 11, 2011 | 07:39 PM
SRTKLLR's Avatar
The Nitrous Outlet Progressive controller can lock out 1st and 2nd then progressively add nitrous starting at 50%(50 if on a 100 shot) and ramp it up slowly. You can start it in second at 10%, 25%, 56%(any percentage) and ramp it up slowly or fast(within .25 or 1.5 sec.). It can be used by RPM also so it can start to spray at 3000RPM and shut-off before the shift. Has a lot of features in a little box, lol.
Old Oct 12, 2011 | 10:16 AM
1-kwik-6's Avatar
I use the FJO racing controller on my setup cheap and has a lot of the same features as the Nitrous outlet unit.
