400 shot and few questions
Old Oct 15, 2011 | 12:34 AM
PONTIAC SLP's Avatar
Default 400 shot and few questions
Hi , I'm running LSX454 by end of this month i'll get it to the dyno to spray 360HP through direct port system on fast 105MM intake and Nano kit and i think it will gain 25% as Nano's mentioned so i guess it will gain 400HP .
Well my injectors are 60LBS and 255 walbro fuel pump , I'm running nitrous out let dedicated fuel system will feed nitrous with C16 .
The rearend is Dana S60 3.54 ratio , RPM level 5 transmission , triple clutch
The car for roll street race , have few questions
* What plugs you reccomend ? I have NGK TR8 and TR9 plugs
* Can i spray at the fifth gear ? i heared some people blows their intakes ?
* What you guys recommend for this setup ?
Thanks in advance
Old Oct 15, 2011 | 12:31 PM
RedRallyeZ's Avatar
I wouldn't run a projected tip TR plug. Look into the BR8EF series for a non projected tip. Im not sure if there is a 9 series BR plug.
Old Oct 15, 2011 | 03:19 PM
mrdragster1970's Avatar
6 & 8 Second Club
Don't they have race tracks there???
Old Oct 15, 2011 | 11:10 PM
No i called them TR8 and TR9 but they aren't , I ran NGK BR7EF N/A for 12:01CR and NGK B8EFS for 250shoot , and NGK 9 is 4 colder then stock for 400HP right ?
No we don't have , Also if we have i prefer to race in the street more fun
Old Oct 18, 2011 | 05:30 PM
Chris@NitroDaves
Guest
Posts: n/a
* What plugs you recommend ? I have NGK TR8 and TR9 plugs
Thanks in advance
* You should be ok with the 9's
* You can spray in 5th but the Tune needs be adjusted because of the load the car see's in that gear. We have customer's that spray at the TX Mile with no problems.
Old Oct 18, 2011 | 07:01 PM
ducatisl's Avatar
Originally Posted by Chris@NitroDaves
...You can spray in 5th but the Tune needs be adjusted because of the load the car see's in that gear. We have customer's that spray at the TX Mile with no problems.
So pull a little more timing?
