Nitrous/Fuel filter recommendation
Old Oct 20, 2011 | 11:30 PM
luvdriven540i's Avatar
Default Nitrous/Fuel filter recommendation
Hello all!
I'm new to nitrous, and recently purchased an NX EFI wet kit, with a Dynotune PC and warmer.
Do the nitrous and fuel filter screened fittings, that are included in some kits, provide adequate filtration or will I still need an inline nitrous and or fuel filter?
Also, being that I just changed the OEM fuel filter, is an inline fuel filter, installed just before the solenoid, even necessary?
Thank you
Old Oct 21, 2011 | 09:04 AM
Carter01's Avatar
I use the stock in line fuel filter and it is fine. I also run an in line nitrous filter from nitrous outlet right off the bottle. My noids also have filters in them. Hope that helps.
Old Oct 21, 2011 | 09:11 AM
Thank you, Carter, it does help.
all the best
Old Oct 21, 2011 | 04:39 PM
Nitro Dave's Nitrous Outlet's Avatar
I always suggest using our Filter with the Nitrous system. You can take it apart and clean it out and you will be suprised at what all it catches that would have been in the solenoid.
http://www.nitrousoutlet.com/catalog...=23&section=78
Old Oct 26, 2011 | 01:09 AM
Blk2kSS's Avatar
I may just have to scoop one of these up.
