I'm about to call it quits...
Old Oct 23, 2011 | 05:16 PM
01SOMZ28's Avatar
Looks like i'm going to eliminate the micro switch and see what happens. If it works, i'll be going back for 10's this Wednesday!...if it works....
Old Oct 23, 2011 | 05:54 PM
custm2500's Avatar
Ph.D. in HUBRIS
I think it will! Good luck.
Old Oct 23, 2011 | 08:52 PM
87silverbullet's Avatar
I think you will be ok. Only switches in my car is a main arming switch and 2 buttons for the 2 stages of nitrous.
Old Oct 23, 2011 | 10:09 PM
slowside's Avatar
I heard buttons are not a good idea, because they have the possibilty to stick?
Old Oct 24, 2011 | 03:08 AM
jaybob's Avatar
When mine did that it was the fuel pressure switch. It was right at the point where it would drop in and out when the fuel pressure fluctuated the slightest bit. I could put a test light on it and blip the throttle and the light would go out. I adjusted it a tiny bit and problem solved.
Old Oct 24, 2011 | 03:18 AM
jaybob's Avatar
To elaborate more, when the system hit, the pressure drop was enough to drop the switch out. Then once the kit was off, pressure was back and kit re-activated, and so on. Hence the surging.
Old Oct 24, 2011 | 04:16 AM
gregrob's Avatar
If you have a fuel pressure safety switch, remove it. They are junk and cause this issue all the time.
Second, my car did almost the exact same thing, and it was a bad engine ground....
Old Oct 24, 2011 | 08:47 AM
ShiznityZ28's Avatar
First i would change the wot switch. I have sceene them do this and speratically. there very cheaply made and can fail. Do you have a controller like an flo etc?
Like silver said above . take all the crap out and start by just using momentary switch you can controll and see if theres any issues. then put just a wot switch in. add 1 part at a time to find the culprit.
Old Oct 24, 2011 | 08:49 AM
....And in this case switches don't work. So, pick your poison.
If my buttons do stick that is what the main arming switch is for. My buttons are the am/fm button and preset button on the steering wheel controls. Those buttons usually don't stick
Old Oct 24, 2011 | 03:52 PM
01SOMZ28's Avatar
I don't have a fuel pressure safety switch.
I haven't had time to mess with anything yet, but could poor bottle psi cause anything like this?
Old Oct 25, 2011 | 12:34 PM
yes The little crappy guage on the bottle is wrong alot. we have 5 bottles and they vary from 100-500 psi off. so if your bottle read 900 it could be 500 or 1300.
if its real low it can cause a surging.
Old Oct 26, 2011 | 10:13 AM
  #32
01SOMZ28's Avatar
That night it was a little chilly and my bottle heater wasn't working. Pressure was only at 700-800....
Old Oct 27, 2011 | 12:44 AM
  #33
TransAm2002's Avatar
Had a problem like this with my Corvette. Turned out to be the mico switch. Replaced it and all is well now.
