Adding nitrous, few question
Old Nov 1, 2011 | 08:42 PM
Bobs-00-SS's Avatar
Default Adding nitrous, few question
Currently my car has ported heads, cam, and full ehxaust. This winter I will be getting a racetronic's pump/hardwire kit, injectors, 102mm mass air, and a faast 102mm combo. I will be also installing a nitrous plate kit as well as a window switch, and timing retard. I will be trailoring the car to Speed Inc. in the spring to have it tuned... will Tr6s be ok with this setup? what should they be gapped at? Also, how much timing should I pull for a 150-175 shot? Will running a plug for the nitrous setup hurt HP very much on the motor? Thanks!
Old Nov 2, 2011 | 01:20 AM
Nitro Dave's Nitrous Outlet's Avatar
With your combo you need NGK BR7EF spark plugs. Gaped at .034.
You will need to remove 6 to 8.degrees of timing.
Do your n/a tune on these plugs as.well and everything will turn out great.
Dave
Old Nov 3, 2011 | 08:03 PM
Bobs-00-SS's Avatar
Thanks! Out of pure curiosity.... what's the difference between a BR7 and a TR7? By the way I will be going with a Nitrous outlet hardlined plate kit....
Old Nov 3, 2011 | 08:36 PM
Carter01's Avatar
Br is non-projected tip and Tr is projected tip. You want non for nitrous apps.
