I sprayed for the first time
Old Nov 9, 2011 | 10:46 PM
GIMPY02's Avatar
I agree with 1badeagle. Spin it higher. I spin my cam only setup to 6800 for 3yrs now lol. Its been fine so far. On a stock 10bolt with 3.23 gears, stock trans , stock lca and pan hard bar with heavy knock off zo6 rims with eagle f1 I 60ft 1.37 on 26" mt et streets. All I have for suspenion are double adjustable strange front struts single adjustable qa1s in the rear spohn ta and a umi dragbar I spray with a 150. So spin it harder and get ur 60's down and the car should go low 11's high 10s in my oppinion
Old Nov 9, 2011 | 10:59 PM
82cetuner's Avatar
get rid of the TR-6 plugs, use a plug that dosnt have a exposed rod. you will burn those things up fast even being 1 step colder
Old Nov 13, 2011 | 03:09 AM
BRYCEROCKET's Avatar
What brand would you recommend?
Old Nov 13, 2011 | 06:09 AM
subhumanzz's Avatar
BR7EF plugs is what has already been recommended. They are one step colder than a TR6 and have a non-projected tip.
Old Nov 14, 2011 | 08:30 PM
Pete91's Avatar
I am on a stock cam and valve train. If I had a cam I would spin it up, but since I don't I'm not really chancing it, but my head gaskets are leaking I noticed it the other day while I was underneath changing the alternator. There are no signs of a blown heads gasket yet. And I prob have a bottle through the motor since I noticed they were leaking. Temp stays under 180 and the car still runs top notch but it's just a matter of of time. I'll prob end up doing the cam real soon if when I re tourqe the heads it still leaks. And br7ef's are on thee way
