Running Purge Lines
I want to run the purge out each of my side vents on the front fenders. The instructions really do not cover running the lines at all so I am just curious about how I should go about it!
I have 3 types of lines: 1 long roll of black tube line. 1 section of stainless braided line. 2 straight pieces of hard line.
I have the purge solenoid mounted right off the purge port on my nitrous solenoid, and have the purge port on my purge solenoid plugged. Therefore I will be running the purge out of the OUT on the purge solenoid.
So how about do I run this? Do I run the stainless line out of the purge solenoid back to a T and then off the T run 2 lines of the black tubing to my purging locations? That is my best guess but I thought I'd clarify. Also, do I mount the hardline in location to purge out of or what tubing/fitting is the end of the purge supposed to be? Thanks!
NitrousNewb Out!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Braided line out of the purge solenoid to a T. Black lines from the T to my purge locations. At my purge locations, I have the bulkheads. Black lines run into the bulkheads, then out of the bulkheads runs my hard lines.
Sound right?
Just make sure they are supported and don't have metal to metal contact on rub areas.
It can jerk when you fire it, and you don't want it going where you can freeze damage something!!
