Best Converter for 300 shot??
Old Nov 25, 2011 | 12:56 PM
n2ols1cam's Avatar
Originally Posted by Black99TransAm
fti 3400 here with a 200 hit. it loves the nitrous...
what cam are you running with that stall?
Old Nov 25, 2011 | 10:51 PM
rmata's Avatar
I'm running an FTI also and have no complaints. My short times aren't really as good as I thought they would be, but I have a feeling it's because I'm not hitting it with enough nitrous. Greg is a great guy to deal with though and I recommend you give him a shot.
Old Nov 26, 2011 | 01:35 AM
Fbodyjunkie06's Avatar
Greg did nothing but help me get my stall set-up for my turbo car. I'd like to get him to tighten up this stall I have now and do some tweaking on it.
Old Nov 26, 2011 | 09:13 AM
n2ols1cam's Avatar
im gonna give him a call on monday and let him know what i need. thanks for the help.
Old Nov 26, 2011 | 09:14 AM
n2ols1cam's Avatar
thanks for all the recommendations guys!
Old Nov 26, 2011 | 12:58 PM
camscam02's Avatar
Greg at FTI hands down. Couldnt be happier with our setup... although with all the new power we may need to get it sent in to make changes and make it that much better
Old Nov 26, 2011 | 03:26 PM
n2ols1cam's Avatar
thanks for the help man! what is your converter speced to? what shot are you on now?
Old Nov 27, 2011 | 08:47 PM
trans am 98's Avatar
niel chance here havent ran it yet (not done with set up) but heard nothing but good things about it. really we can only tell you where to go its up to you on which one you rather choose good luck though hope you like your converter
Old Nov 28, 2011 | 04:54 PM
n2ols1cam's Avatar
thanks for the help guys!
Old Nov 28, 2011 | 06:38 PM
camscam02's Avatar
I have 150 in each stage right now. My converter goes to 4100 on the brake and flashes to about 5400-5700 depending on certain things I do in the tune up. Drops 800 on the shifts
Old Nov 28, 2011 | 08:00 PM
TA6spdRDC's Avatar
just got my converter ordered from Greg at fti. spec'd for a 250 hit
Old Nov 28, 2011 | 11:31 PM
  #32
soundengineer's Avatar
for FYI...
if you were saying your car would buck and shake on a 3500 stall...
then you have problems with your tune...
I have a much bigger cam and had no issues with my car when it was an M6....
lugged it along in 6th gear as a daily driver...
also, your MS4 will be fine with nitrous... you may need to jet it larger to get an actual 300 hit because you will be blowing some of it out the overlap in the cam...
a smaller cam with a bigger split and less overlap will typically benefit more from nitrous
as far as stall speed...
its sort of gonna depend on what you want to do and how you want it to drive on motor.
if you drive your car a lot on the street, then a slightly lower stall speed might suit you better
if its an all out racecar, then it would better suit you to go with a higher stall..
Lots of good vendors... Yank, FTI, mentioned in previous posts... bot make great converters and can both spec them to what you want or need.
and Just because you order it as a "3600" doesnt mean you will get a "3600"... it may be a little less or a little more.. and on nitrous...its going to be more....
you really need to know what the power curve of your engine looks like to determine what size stall will suit you best, and the vendor you chose to make it, will benefit from the same data.
also, the series of converter you get will also determine some of its characteristics.
example... a Yank SS3600 will be considerably softer and looser on the juice compared to a Yank PY3600 race converter
Old Nov 28, 2011 | 11:39 PM
  #33
navyblueSS's Avatar
Ordered a new converter from Greg at FTI today, can't wait to get it in.
Old Nov 29, 2011 | 09:51 AM
  #34
n2ols1cam's Avatar
damn that stays up in the rpms! have you improved your times at all by going to a 2 stage?
Old Nov 29, 2011 | 09:58 AM
  #35
n2ols1cam's Avatar
Originally Posted by soundengineer
for FYI...
thank you very much for the great information. i do drive the car on the street a lot but i am not too concerned about driveablity so i would not mind a big stall. i think i am going with FTI.
how much do you need ill have to spray at it to get an actual 300? i am hoping my pump will keep up with a 300 shot, i am a aeromotive 340 with a hotwire kit. hopefully the pump can keep up, so far its done fine on the 200 shot.
Old Nov 29, 2011 | 06:56 PM
  #36
Carter01's Avatar
tell him Carter01 and Camscam02 sent you, greg will take good care of you.
Old Nov 29, 2011 | 08:43 PM
  #37
camscam02's Avatar
We didn't go to 2 stages for a hp gain, we run a couple heads up classes on a limited tire and it gives us more flexibility to help it leave. With that said I haven't got a clean pass yet with the new plate so maybe it will pickup.
Yea sir!
Old Nov 29, 2011 | 11:29 PM
  #38
Speed Density's Avatar
hashtagBMW
I had an FTI 4000 behind my LT1, never got to run it but greg was really helpful in building it.
Old Nov 30, 2011 | 09:10 AM
  #39
SuperSlow02's Avatar
I spent probably close to an hour on the phone with Greg, his converter did exactly what he said it would do. I've only had one track visit to where I can say was an actual test session, which was still crappy on my part since I decided to enter a KOS event which kept me from touching the car...lol. Anyways, NA the car went 1.58 leaving at 1k Rpms instead of putting it at 3800 on the 2step, I tried once but it just blew the tires off...so deffinently could of gone quicker. Then on a 150 shot, it went 1.45, carried the tires for about 6ft then unloaded and spun the rest of the 60ft. No doubt going with Greg has been the best choice I've made with the car in 2yrs
Old Nov 30, 2011 | 12:19 PM
  #40
n2ols1cam's Avatar
i will be sure to mention your names, thanks for the help guys!
oh i see. well good luck with the car man, very impressive what you did with it.
