Re-wired my nitrous
Old Dec 6, 2011 | 08:54 PM
Cape T/A's Avatar
Default Re-wired my nitrous
I actually did this a few months back, but I figured I would share it.
I added a progressive nitrous controller, fuse block, and worked a electric cutout into my switch panel.
My pile of parts
Im pretty picky (or crazy) about some things so first I drew out a wiring diagram. It helped out a bunch though when I was actually doing the wiring.
This is while is was straitening out the old wiring mixed with my new parts.
I made this plate of aluminum to fit in the glove box to mount everything to since I didnt want to drill holes in the actuall glove box.
My switch panel wired up
Some of the wireing done and labeled
The wiring all done
I was really wanting to get the microedge+ but I they appearantly quit making them shortly before I ordered my parts, so the next cost efective progressive controller I could find was the NOS mini progressive controller, it also has a dual stage feature.
Old Dec 6, 2011 | 08:58 PM
the crusty pirate's Avatar
Your attention to detail is awesome. Looks great dude.
Old Dec 6, 2011 | 09:04 PM
Cape T/A's Avatar
Thanks! It actually didnt come out as neat as I had hoped for, but fitting all those wires neatly into that small of an area is tough!
Old Dec 6, 2011 | 09:09 PM
a4ls2goat's Avatar
Looks like a headache..lol..
Good work man!
Old Dec 6, 2011 | 09:28 PM
Cape T/A's Avatar
Good work man!
well it took me 3 or 4 nights to do it all, lol
Old Dec 6, 2011 | 09:49 PM
wws699's Avatar
Nice job! And nice schematic
Old Dec 7, 2011 | 04:39 PM
Chris@NitroDaves
Guest
Posts: n/a
Extremely nice Re-Wire job!!!!!!!!!!
Old Dec 7, 2011 | 06:14 PM
Cape T/A's Avatar
Thanks a lot!
Old Dec 9, 2011 | 04:33 PM
Cape T/A's Avatar
Thanks! It was my first time making a wiring diagram, didnt turn out too bad, took me some time though.
Old Dec 9, 2011 | 06:40 PM
CNTLSE 1's Avatar
Where did you get the fuse block and some of those parts? This is exactly what I want to do
Old Dec 9, 2011 | 08:25 PM
Sales1@Texas-speed's Avatar
Great job Nathan!
Old Dec 9, 2011 | 09:13 PM
krissoto's Avatar
very nice buddy, I think u did a fantastic job.
Old Dec 10, 2011 | 01:48 AM
99 PROBLEMS's Avatar
WOW! the is some kick *** wiring!!!!!
Old Dec 10, 2011 | 04:45 PM
Cape T/A's Avatar
I got the fuse block from auto zone, and the terminal strip (which I used for my grounds) from radio shack, they had a jumper strip for it so I jumpered it all together and ran my main ground right in the middle of it. The labels I made for the wire are a heat shrink tube, I printed those off of a Kroy labeler which I have access to at work.
Old Dec 10, 2011 | 06:19 PM
CNTLSE 1's Avatar
Thanks for the info. What is the big box hanging out of the compartment?
Old Dec 10, 2011 | 08:22 PM
Cape T/A's Avatar
Its my N/A - N20 switch. My tuner wired that up to my ecu, I believe it uses a resistor to trick the computer into thinking the engine is running hot so it pulls timing when the switch is on. My tuner has it set to 8* of timing I believe. Its also wired in series with my arming switch so the nitrous will not activate with out it turned on.
Old Dec 10, 2011 | 08:26 PM
Cape T/A's Avatar
Originally Posted by Aaron@Texas-Speed
Great job Nathan!
Thanks a lot sir!
If only it would run as good as yours!
I do what I can!
Old Dec 10, 2011 | 09:47 PM
CNTLSE 1's Avatar
gotcha so basically your running a timing a twister type box and a the controller that acts as a window switch?
Old Dec 11, 2011 | 06:09 AM
Cape T/A's Avatar
correct.
Old Dec 12, 2011 | 09:43 AM
Z284U2TRY's Avatar
Nice clean install.
Do you have relays to drive the noids or is that box enough?
