New To Nitrous... Need help.
Old Nov 15, 2001 | 07:34 AM
BIG NUGGETS's Avatar
Default New To Nitrous... Need help.
Well I'm new to the world of Nitrous and I need suggestions, tips, precautions, etc. My vehicle is an 98 Z/28 A4 w/3.23/MMS Stage 2 11.3 compression/MMS 229 cam/stock displacement bottom end/ 4900 stall/Shifting at 6800RPM/stock fuel system. I'm looking to set up a completely hidden kit(maybe under the intake manifold), 75 shot(nothing too big,just enough for the advantage). Sooooo.....
1. Creative ways to hide it?
2. What upgrades to the fuel system are recommended.
3. What safety precautions should be taken?
4. Am I crazy?
Old Nov 15, 2001 | 07:59 AM
RyanJ's Avatar
SSU Moderator
Default Re: New To Nitrous... Need help.
uhhhh.....yeahhh.....
im not gonna say what i want to say, but if you dont have the advantage with that combo i would suggest a NOS 5177 dry kit. you can hide it well and with MUCH lower shiftpoints, an inline pump (for good measure), and a plug change you can run 75-80hp easy.
here: http://hometown.aol.com/paulw98z/myNOSsystem.html
Ryan
Old Nov 15, 2001 | 08:08 AM
69Muscle's Avatar
Damn That's the setup I'm aiming for. Go with the NOS #5177 like Ryan said. It's the easiest to hide and fairly easy to install. You'll need a MSD window switch, intank or inline fuel pump, WOT Switch and probably a new Tranny <img src="images/icons/smile.gif" border="0"> , oh and new injectors!
Old Nov 15, 2001 | 08:09 AM
69Muscle's Avatar
4900 stall?! How the **** do you drive that thing?! <img src="images/icons/grin.gif" border="0">
SORRY I DIDN'T REALIZE THAT THE F WORD WAS NOT ALLOWED <img src="images/icons/smile.gif" border="0">
[ November 15, 2001: Message edited by: Fireball ]</p>
Old Nov 15, 2001 | 08:54 AM
I hear you(need advantage?), but there are so many H/C cars around it's neccessary. A bolt on H/C car w/ spray can easily run mid to low 11's. [quote]4900 stall?! How the **** do you drive that thing?! <hr></blockquote>It's just a flash stall, fairly loose, but it works well.
I was thinking about shifting at 6200 or so. Good enough? Would you suggest upgradinging in jectors?
Thanks again
Damn F word just won't go away <img src="images/icons/rolleyes.gif" border="0">
Old Nov 15, 2001 | 09:28 AM
69Muscle's Avatar
Yeah you'll need bigger injectors something along 40lb/hr with that setup just to be safe.
Old Nov 15, 2001 | 10:36 AM
Colonel's Avatar
Bigger pump (or an inline helper) and bigger injectors. Ford SVO 30s would be fine (they actully flow 36 lb at the LS1's 58 psi because they're rated at 44.5 psi.) A fuel pressure gauge and Autotap would be MUCH advised!
You'll want a tighter converter if you get to spraying much more than a 75 shot for best results, otherwise it'll be stalling the moon! <img src="images/icons/shocked.gif" border="0">
And of course like the others said, cooler plugs.
[ November 15, 2001: Message edited by: Colonel ]</p>
