A4 drivers + window switch
Old Nov 22, 2001 | 12:33 AM
SIR's Avatar
SIR
Default A4 drivers + window switch
What rpm pills are you using for ON and OFF using a 3500 stall tc??? Does 3500 ON 6200 OFF sound good?
Old Nov 22, 2001 | 03:09 PM
Jfulcher's Avatar
Default Re: A4 drivers + window switch
I have a Yank ST3500, and I have my pills set to 3200 on 5800 off, shifting at about 5900-6000.
Old Nov 22, 2001 | 08:33 PM
SIR's Avatar
SIR
Thanks for the replys
Yeah I had mine at 3000 ON and 5600 OFF at the track. I had forgotten to bring the extra pills to change.
Well, I have a ST3500 and 3.42 gears and when I was launching on motor I was gettig very low 1.6's. Then when I tried using the TNT 100 shot, I just spun and had to get off it. I guess I will try it at 3500 and move up from there. I am running BFG DR.
Old Nov 23, 2001 | 12:07 AM
Slow Z28's Avatar
depends, do you want to launch on the NOS or not? i have a vig3200 stall convertor, and when i had it set for 3200 on and 6000 off, it would launch, then it would kick in the NOS. it would be just a split second later. i had it set for 3000 on and 6000 off. works the best for me. actually now, i don't run with the window switch, just a WOT switch. the convertor flashes up to it's stall point and it's on when I'm WOT. hope this helps. i had a stock motor, shifting at like 6200, so that's why i turned it off early at 6000. good luck man!
Chris
Old Nov 23, 2001 | 12:17 AM
Chris Spiess's Avatar
My plans for setting up have to wait for spring since I didn't get everything setup before the season ended here. My plans are to start around 4000RPM lower setting (3500 stall) to get my stock rear off the line and rolling before the nitrous hits. Seems to make sense, anyone?
Old Nov 23, 2001 | 12:38 AM
Slow Z28's Avatar
i have the stock rear on my car. don't know how long it will last though with my 60's. with a vig3200 and the TNT 100 shot coming on at 3000, i pull 1.5's. 4000 is gonna be too high in my opinion. like i said, with my 3200 stall, the 3200 on setting on the window switch would allow me to launch, and then about 60' out the NOS would kick in. so that was saving my rear a bit, but still pulling high 1.6 60's. i would start at 3500 for you and then figure out how that works to what you want it to do.
Chris
Old Nov 25, 2001 | 08:51 AM
Black Sunshine/ 00SS's Avatar
I cant wait until Harlan comes out with his window switch. No pills to worry about, and adjustable in 100 RPM increments, just like his shift light <img src="images/icons/grin.gif" border="0"> As to when it will be out, well, Mr Harlan?
