arming switch question ?
Old Nov 23, 2001 | 10:37 PM
blackend02's Avatar
Default arming switch question ?
where do i find aignition power source to hook up my arming switch?
Old Nov 23, 2001 | 11:32 PM
LIL SS's Avatar
Moderator
Default Re: arming switch question ?
In most cases people wire it straight to the battery..
Old Nov 24, 2001 | 12:32 AM
N2O Guy's Avatar
I recommend using an accessory pin in the fuse panel. At least if your using a relay. If wired properly it shouldnt pull amperage through the car or circuit. Wire it... Fuse panel to battery terminal on toggle, accessory side to power in on microswitch, switched side of microswitch to pin 85 on relay, pin 30 on relay to battery post,pin 87 on relay to power side of solenoids, other solenoid wires to ground, pin 86 to yellow wire on the MSD window switch. *If your using a fps switch put it in between the yellow wire off the msd and the pin 86 on the relay. Hope this helps. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
