Blew a fitting right off!!
Old Nov 24, 2001 | 11:57 AM
Black Sunshine/ 00SS's Avatar
Default Blew a fitting right off!!
Woke me up quick. I fixed a leak at the solinoid by using liquid teflon. Hooked up the bottle, & when I turned on the bottle, the hose connector blew right off. So, either I had the bottle pressure too high, or I had a weak connecter?
Someone tell me if I have to get a new hose, or if I can get a standard high preasure fitting to put on there, like by Aeroquip.
Old Nov 25, 2001 | 12:03 AM
Chris Spiess's Avatar
Default Re: Blew a fitting right off!!
Do not use a standard AN fitting. You want to use a hose end made specifically of high pressure hydralic systems - ie brake, power steering. I know Earl's and Russel both have the appropriate fittings, and I would assume Aeroquip does as well.
Old Nov 25, 2001 | 12:29 AM
y2khawk's Avatar
Harold
was this fitting on the feed hose to the motor??
If it's -4 AN teflon hose i have the fitting you need <img src="images/icons/smile.gif" border="0">
call me, i'll answer this time <img src="images/icons/rolleyes.gif" border="0">
Old Nov 25, 2001 | 08:18 AM
Matt, I'm up north right now. I'll have to get ahold of you when I get back Mon. It is the main line, but I dont know if it is Teflon or not. What kind of fitting do you have? I ordered one, that is a high presure, but is usually used for brake lines. I thought about contacting Compucar on Mon & see what they reccomend. Are your window switches available yet? I see them listed on your site.
Old Nov 25, 2001 | 11:15 AM
ExtremeZ28's Avatar
what kit and did you go wet or dry??
Old Nov 25, 2001 | 01:18 PM
Wet, it was a used kit, & I got a good deal. Might step up to a TNT, or a NX, weighing options.
