200 shot good idea for first shot
Old Dec 29, 2011 | 09:02 AM
1998MysticZ28's Avatar
Default 200 shot good idea for first shot
Talked to the guys over at nitrous outlet. Decided Im going to buy there 98=02 complete plate kit. I want to put the kit on it and go for a 200 shot. This is my first time using spray so I was just curious what you guys think. The spark plugs will be 2 deg colder and I will order the LC1 Wideband through Nitrous Outlet as well. So all that leaves me is to but a switch panel to wire everything too correct?
Is there anything else I need? Would my fuel setup be fine with just a 255 pump and 42' injectors?
Thanks guys
Chris
Old Dec 29, 2011 | 09:18 AM
ATVracr's Avatar
No...
Old Dec 29, 2011 | 09:27 AM
2QUIK4U's Avatar
I would go with 100 shot first and then work your way up. You will be surprised at how much you will gain. My H/C car gained 145/192 jetted for 100 shot.
Old Dec 29, 2011 | 09:32 AM
okay I understand, sounds like Im asking for trouble out the gate. My fuel set up will still be good correct?
Old Dec 29, 2011 | 10:59 AM
karpetcm's Avatar
I would not do 200 shot at first at all. Start off at 75-100 make sure your A/F is good and go up from there checking plugs. You put money into the car just make sure its all good before you step up to 200 shot.
Old Dec 29, 2011 | 09:21 PM
red 95 t/a's Avatar
Go big or go home lol. No seriously work you way up
Old Dec 29, 2011 | 10:17 PM
Go On 3's Avatar
start off small.. once you are sure its all working right you will quickly start upping the jets, just remember to take your time and do it right. 75, 100, 150 until you meet your goal
