Backfire after spraying
Old Jan 10, 2012 | 09:12 PM
jrzdude's Avatar
Originally Posted by MyFirst01
Would a guy still have this problem with a wet plate system?
I have a wet plate system myself, so I guess it could happen. I get what you're asking though, cuz I thought the plate systems were designed a way so that didn't happen
Old Jan 10, 2012 | 09:19 PM
white2001s10's Avatar
Originally Posted by jrzdude
Instead of tuning, could I maybe step a size down on the fuel pill to lean it out a little bit?
That's exactly what I meant by tuning your wet N2O system.
I would try it, and hope that you have no lean cylinders.
Unless somebody turned DFCO off in your tune, then it's there and functioning fine. DFCO turns your fuel injectors off, not your spark.
If you decelerate in gear, then DFCO will engage. The fuel burning up in your exhaust is left over from your wet N2O system, not your injectors.
During DFCO activation your injectors will deliver no fuel at all, unless they are leaking.
If you shift to neutral at the end of your run and coast, then DFCO does not engage, and often the over-rich condition that the fuel puddling causes will kill your engine.
Old Jan 10, 2012 | 09:20 PM
MyFirst01's Avatar
Yeah thats half the reason I got a plate system (the other half being I didn't want to drill into my intake). I hope don't have this problem!
I don't know if it has anything to do with it, but I will only be spraying a 100 shot. So maybe less fuel/n2o being sprayed into the intake so no puddle maybe?
Old Mar 21, 2012 | 12:12 AM
sweet99ss's Avatar
Thread is a cuple months old, but I noticed my car does the same thing. After a long nitrous pull with my cutout open the exhaust pops a little bit when I let off...
Old Mar 21, 2012 | 03:11 AM
kidcamaro98's Avatar
mine has been doing the same thing for well over a year now. 100 shot or a 150, it doesnt matter. I am also a wet plate kit. It "pops" and spits flames as soon as I let off from a nitrous run. I dont have any cutouts tho. This is through my full exhaust.
I actually have a video clip of it....
from :32-:36 seconds you can hear it if you turn the volume up and at exactly :36 you can see my center mount light up from the flames.
http://www.youtube.com/watch?v=4Phdk...ure=plpp_video
never really worried about it as pretty much every nitrous car I have been around (mostly c6's) have done it.
