How much spray?
Old Nov 29, 2001 | 08:04 AM
NO CATZZ's Avatar
Default How much spray?
How much spray(dry or wet) can an internally stock LS1 handle. And what is the weakest link...pistons, rods, head gaskets? I want to run as big of a wet system that I can without tearing into the motor.
Thanks
Old Nov 29, 2001 | 06:06 PM
Country Boy's Avatar
Senior Member
Default Re: How much spray?
I asked James at TNT when I got my 200 shot pills. He said that the weakest link would probably be the head gaskets. Im running a 200 wet for now.
Old Nov 30, 2001 | 12:07 AM
Colonel's Avatar
Somewhere between 100 and 500 HP. <img src="images/icons/wink.gif" border="0">
Seriously, this isn't a question that has a simple answer. If you do it right you might run a 300 shot for a long time with no trouble or you might burn a piston on a 150 shot.
I feel a 125 shot is really safe and 200 is fairly safe if done correctly.
Weakest link? Could be any of the above. More likely the pistons, rings, or head gaskets.
