Times to expect from 150 shot????
Old Dec 3, 2001 | 07:02 AM
MAFs 00 Ws6's Avatar
Default Times to expect from 150 shot????
I will be installing the NX wet kit on my 2000 Ws6 6spd and was wondering what times should I expect to run? I want to be in the mid to low 11's. Just curious as to what times to expect at the track. I will be staring out running a 50 shot and then work my way up to the 150 shot. Need to get a feel for how the car will jump when the nitrous kicks in....Thanks
Old Dec 3, 2001 | 08:55 AM
DJ's Z's Avatar
Default Re: Times to expect from 150 shot????
There are so many diff. variables to consider...track prep, what tires your using to give you the best 60', if the stock clutch will hold, and any other mods to the car except for the NX system. If you can get the car to stick and the factory clutch not slip too bad... you may have the times your lookin' for. That may be asking alot though. Good luck !! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Dec 4, 2001 | 12:38 AM
Good deal. Yea I will be installing the CarTek clutch, HALs front shocks and springs, along with the Pro 5.0 shifter. Tires I will burn up the Goodyear F1's that are on the stock rims, and then I will be putting on the Nitto's. So the times that I am looking for are reachable...Just depends on my driving....thanks for the help. I really appreciate it a lot..thanks again..Michael <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
