Heads cam ls1. What's the a good nitrous kit to get?
www.nitrousoutlet.com is the ONLY nitrous company with which I will do business at present.
Best customer service out there, and TOP NOTCH stuff... Cant go wrong.
Go with a plate kit. Best flowing / atomizing plate out there.
With a dry kit you will need injectors to go with the kit if you don't have bigger ones yet. You will also need a controller to add the extra fuel for the nitrous or get it tuned and get the tuner to make the pcm pull timing and add fuel.
To me, its a pain in the ***. Get a wet kit and bolt it on and go. All you will need is colder plugs a timing tuner to pull timing. Plus, you can tune it easier than a dry.
