Smoking?
Air doesn't weigh anything, and everyone should weigh the bottle before paying for the fill.
Also, if the bottle is under filled, it does not lean out the tune up, it goes fat.
After my first run on the 225shot it started to steam and the hit was like hitting the rev limiter. I opened the valve in the pits and it was all air!
Lean or fat, you are most likely right.
All i know my car was knows as the Steam Train after that!
In my book all info is good info. So I always weigh my bottles after each run.
I know some guys will say why when you can only use once??
I like to know if something is changing.
If you slowed down a little, and the bottle weighed more then it should then you know to check the delivery system.
Maybe one of the noids is getting weak?? A wire is coming loose??
Then with the computer info, you can trouble shoot quicker.
I had my WOT switch bend this year and it slowed down 2 pass' in a row.
After checking the weight of the bottle, and the computer I knew the noids were fluttering and not an engine issue.
Knowledge is your friend, record all info, mild or wild combinations alike!!
The plugs go from 8 to 2 in order
also finished up the lleakdown
dry-wet
2: 160-175
4: 150-185
6: 170-190
8: 160-200
these side was not as accurate. Didnt get to double check #8 as we did #5 since it went up to 220 then down to 185 after I redid it
Shouldn't matter too much though, right?
I heard the #s should be 10% to 15-20% in difference? If someone could verify and also give me an opinion it would be greatly appreciated.
When are you seeing the smoke? Idle, wot N/A, or wot nitrous?
Obviosly you now know the spark plugs you were using was wrong.
What was your air fuel?
Is your pcm N/A tune stock?
Dave
However if i end up driving this to the ground then im going to look into a lq4/9.
