What size injectors necessary?
Old Dec 28, 2001 | 04:08 PM
Dan00Hawk's Avatar
Default What size injectors necessary?
What size injectors would a heads/cam car putting out around 400 RWHP N/A need to also handle a 100-125 dry shot? Ultimately, what size injectors are necessary/safe to supply enough fuel for an LS1 that could be putting down 500-550 RWHP? Someone here hopefully knows the calculations and math necessary to figure that out.
Also, will it likely be necessary to upgrade the fuel system with an inline pump with this type of setup?
Thanks.
Old Dec 28, 2001 | 09:09 PM
383LQ4SS's Avatar
Default Re: What size injectors necessary?
Ford 42lb injectors and Wlbro 255lph intank pump along with reprogramming from Ed Wright did it for me. All dry through the injectors I made 611 to the wheels and was pig rich on the first run...backed th MAFT down 4% to acheive 12 to 1 AF ratio
