Need some advice
Old Dec 28, 2001 | 11:23 PM
BlackSuperSport's Avatar
Default Need some advice
I had the NX remote bottle opener but it was too loose on my TNT bottle so is there a remote opener that actually fits & works? Also the TNT bottle warmer is supposed to connect to the cig lighter, what's up with that? What bottle heater should I get because the TNT is not going to work. Also do I need a window switch for my A4. I was told that I didn't but is that true? Thanks!
Old Dec 30, 2001 | 10:49 AM
Default Re: Need some advice
Anyone?
Old Dec 30, 2001 | 11:06 AM
Slowhawk's Avatar
LS1Tech Sponsor
This is the first time I heard of a NX opener too loose for a TNT bottle ussualy you have to file the NX ring to fit.
I'm sure you can hook up the bottle heater to a switch by cutting the wires.This is new to me too <img src="images/icons/confused.gif" border="0">
I would run a window switch for cutting the N2O before the shift.This will extend the life of your tranny.
Old Dec 31, 2001 | 11:33 PM
FearMyZ28SS's Avatar
I have a '99 SS A4 with a 125 shot of N20, I've managed to hit the rev limiter numerous times while running the juice... Fortunatly the Window Switch turns the spray off prior to (since rev limited cuts fuel not spark)
Like slowhawk said, just cut the cigarette adapter off and hard wire it to a switch. If you're not sure which is pos and which is neg, plug it into a cig lighter and then poke the tester through one of the wires. (i'm not trying to be a wisea$$, not sure of your electrical experience...)
