Nitrous accessory ports
Old Feb 28, 2012 | 10:39 AM
coolmanvette75's Avatar
Default Nitrous accessory ports
Hey guys quick question. I need at run a gauge, blowdown tube, and pressure sensor for the heater on my set-up. The problem is that I only have 1 accessory port on my NOS hi-flow bottle valve. Any suggestions on what I can do?
Old Feb 28, 2012 | 11:08 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Well we have a couple of manifolds that you could use. What size is your feed line?
Old Feb 28, 2012 | 11:42 AM
-4an.
Old Feb 28, 2012 | 02:56 PM
Well we have this manifold that would work great for you.
http://fourm.nitrousexpress.com/prod...ils.php?id=227
This would allow you to run who more accessories after the valve.
Old Feb 28, 2012 | 09:05 PM
So you just screw this onto the bottle nut?
Old Feb 28, 2012 | 11:08 PM
Nitro Dave's Nitrous Outlet's Avatar
This is what you will need.
http://www.nitrousoutlet.com/catalog...3&product=3786
Our manifold fitting is a dual accessory port and it swivels. With the style bottle valve you have this will be very useful in order for you to be able to place the fittings in the stoping position you need.
This will screw onto your bottle nut. Then the main feed line will screw onto the oposite end. The center of the fitting will have two 1/8 npt holes. In these holes you can put your gauge and pressure switch.
The blow down tube will hook to the NHRA fitting on the bottle valve. If your bottle has this fitting it will have a 8 an thread off the valve. If it does not you will need to purchase the NHRA valve. Can you post a picture of your bottle set up?
Dave
Old Feb 29, 2012 | 05:13 PM
Yes i would screw on to the bottle valve. If you need one that swivels we do also offer on that swivels.
http://fourm.nitrousexpress.com/prod...ls.php?id=1514
