Arming switch for an M6
Old Jan 2, 2002 | 01:43 PM
MAFs 00 Ws6's Avatar
Default Arming switch for an M6
Was wondering where would be the ideal spot to place the switch? Need to have a quick access spot in order to activate after shifting gears?? BTW this is for a T/A. Pictures would rock but any ideas will help me out a lot. Thanks..Michael
Old Jan 2, 2002 | 02:05 PM
Taco's Avatar
Default Re: Arming switch for an M6
I've heard stories of people using the stereo control buttons on the left side of the steering wheel for spray buttons. Would be awesome, completely hidden, and have one hand on the wheel and one on the shifter at all times.
I would like to see the how-to on this.
Taco
Old Jan 2, 2002 | 02:50 PM
Now that would be slick...I too would like to see the how to on that....
Old Jan 3, 2002 | 04:25 AM
Ghost SS's Avatar
Just use a WOT switch. When you shift just let off the gas so the nitrous will shut off, and floor it again to activiate it. You should only be running nitrous at WOT anyways.
Old Jan 4, 2002 | 12:49 AM
badazz99ls1's Avatar
arm the system on the line, set the window switch at 3300 and 5800 and floor down the track, the window switch will cut the nitrous on the shifts, if you miss a gear!! <img src="gr_eek2.gif" border="0">
Old Jan 4, 2002 | 06:55 AM
Thanks for the replys...but I already have the WOT and window switch installed. I don't want to engage the N2O until 3rd gear so I would need to find an ideal place to place the switch in order for me to activate the system easly while shifting into 3rd gear...thanks <img src="gr_images/icons/wink.gif" border="0">
Old Jan 4, 2002 | 11:14 AM
Fireball's Avatar
well..if you wanted to start in 2nd gear all you need is a microswitch on the shifter in the normally closed position. If the shifter is in first it won't spray. Once you leave first it will spray. (the switch was mounted to the base of the shifter and the stick activated it) I'm sure you could use the same idea and use 2 switches in series (one for first gear and one for 2nd gear) that would prevent spraying in those gears.
I activate my second stage of nitrous in this manner (on the 1-2 shift)
Old Jan 4, 2002 | 03:57 PM
Fireball's Avatar
wire the switch in reverse (normally closed) so that if the shifter is in first gear it OPENS the switch and shuts the nitrous off. Like I said you can put one on for 2nd gear too and wire it in series so if the car is in first OR second the nitrous won't flow.
Old Jan 5, 2002 | 12:18 AM
LS1powerN20's Avatar
mine is in the ash tray, very stealthy, but sometimes hard to get to.
Old Jan 5, 2002 | 12:24 AM
Fireball I am not following you with the switch??? Would that only allow the nitrous to spry in 2nd gear or would I then have to have a switch for all the gears?? Sorry I just can not picture the set up... <img src="images/icons/confused.gif" border="0">
Thanks...Michael
Old Jan 7, 2002 | 06:41 AM
Fireball I like that idea...One more question for ya..what kind of switch did you use and where did you get it from?? Thanks again...Michael
Old Jan 7, 2002 | 10:04 AM
LIL SS's Avatar
Moderator
You use a natrualy closed switch. You can find them throug summit, or even some local parts stores will have them..
Old Jan 7, 2002 | 10:43 AM
Fireball's Avatar
I used a standard microswith (just like the ones used for most WOT switches) They can be used either normally open or normally closed.
