150 dry shot realistic
Old 03-01-2012, 10:10 PM
karpetcm's Avatar
Default 150 dry shot realistic
Im looking to go to a 150 dry shot from my 125 dry shot. Only mods i want to do is get the casper fuel pump booster so get an extra 2 volts to the stock pump and upgrade the injectors with ofcourse a re tune for the 150 dry shot. Should that be ok, i think even at that i might be lucky to get 440-450 rwhp give or take a bit on a wet system higher but i like my dry set up and i think if i up the voltage to the stock pump and get bigger injectors with the re tune hopefully ill be ok, what do you guys think. Ive done alot of research going to a wet shot 150 is nice but i really like my dry set up.
Old 03-01-2012, 10:17 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
As long as you do those supporting mods and be prepared to spend a little time on a dyno tuning it, it will be completely possible.
