Calling N2O Vendors
http://www.nitrousoutlet.com/catalog...=15§ion=42
May I ask why a dry system?
In your post you state you will not need to pull timing with a dry system and that is not the case. You will still need to remove the timing.
I assume you plan to spray before the mass air meter and let the pcm adjust the fueling? If doing this with a nozzle please understand nozzle placement will play a huge roll in the tune up. The nozzle simply moving and changing the flow path of the nitrous can alter the tune.
If going dry our Halo system is very hard to beat. Due to its design it completely saturates the air intake track, evenly distributing the nitrous through the mass air meter.
Another option is to use the nozzle after the mass air meter and use EFI lives custom operating system to add the extra needed fuel.
Keep in mind with going dry at some point you may need to upgrade the injectors as well.
Please feel free to ask me any questions you have before spending your hard earned money. You will not find another nitrous sponsor that understands this platform and nitrous as much as I do.
I also see you are in Fort Hood. Im in Waco, right down the road from you.
Dave
