solenoid Maintence???
Old Mar 21, 2012 | 03:23 AM
kidcamaro98's Avatar
Default solenoid Maintence???
well usually I put my car away for the winter, however this year we didnt really have a winter so I drove my car pretty much everyday still.
Now, being that I havent even used my nitrous since mid fall, I want to pull my solenoids apart and grease them up and such before the first time I spray in spring again so I dont end up with a sticking solenoid or anything. The solenoids on my car are less then a year old now with around 8 bottles through them and I have never had them apart. They are the HSW powermax bottom port solenoids.
What I am asking is, is there anything I can do for maintenance?
Old Mar 21, 2012 | 04:51 AM
INTENESS's Avatar
I would say blow em out with a air gun then spray with some wd-40.Make sure your screen on the inlet on the nitrious is clean.Also if you dont have a filter in line your main feed line I recommened u put one in.Let me no if your going to lebanon ill try make it,I like going to atco if u wont to go there.
Old Mar 21, 2012 | 06:36 AM
SuperSlow02's Avatar
I don't believe any of that is part of maintenance. Take them apart, inspect for debris, and the condition of the piston seal, and Oring.
Old Mar 21, 2012 | 05:59 PM
thanks bud. I dont believe my nitrous main feed line has a screen in it. I can put any little screen I cut in there right? Doesnt hafto be a certain one?
not sure when im going to lebanon. Prolly sometime in april when they open up. Never been to atco.
Old Mar 21, 2012 | 06:07 PM
INTENESS's Avatar
Atco is a great track,track prep is second to none,bit more of ride for ya but worth the extra drive.There open now so if u decide let me no.I would put a inline filter right off the bottle.
Old Mar 21, 2012 | 06:09 PM
thanks.
problem is with going far away to run is Im always worried about breaking something and then im screwed...
Old Mar 22, 2012 | 09:11 PM
Nitro Dave's Nitrous Outlet's Avatar
See it this helps.
http://www.nitrousoutlet.com/manuals...aintenance.pdf
Old Apr 2, 2012 | 02:17 AM
EngineBuilder59's Avatar
That sounds about right
