How much can I spray?
Old Jan 22, 2002 | 06:04 PM
JPJBC's Avatar
Default How much can I spray?
I want to be safe and I dont have an ATAP or a MAFT. How much of a dry shot would be pushing it. Few more weeks and I will buy an ATAP but I dont know if I can wait that long to spray. So what is it 35,50,75,100??? Thanks Joey
Old Jan 22, 2002 | 07:55 PM
EVIL's Avatar
Default Re: How much can I spray?
i have the 50 jets in and hit it 3 or 4 times tonight (after install) and didnt hook atap up and no maft on my car and it seemed to be fine...pulled real hard in the lower gears!
Old Jan 22, 2002 | 09:48 PM
ROBS SS's Avatar
i went right to a 100 shot (wet), with no a tap, with no problems, going to try the 150 this weekend!
Old Jan 22, 2002 | 10:18 PM
XSuROsISX's Avatar
Depending on what year you have, 98 has the bigger pump and injectors, I have run a 200 dry shot, but if you have the 5177 kit you can run it wide open without jets and be fine, expect about 125HP that way...
Old Jan 23, 2002 | 04:54 AM
love2xlr8's Avatar
The consensus seems to be a 125 shot dry. If you go wet you can see the results in sig <img src="gr_grin.gif" border="0">
Old Jan 25, 2002 | 02:17 PM
Chris Spiess's Avatar
[quote]Originally posted by XSuROsISX:
<strong>Depending on what year you have, 98 has the bigger pump and injectors, I have run a 200 dry shot, but if you have the 5177 kit you can run it wide open without jets and be fine, expect about 125HP that way...</strong><hr></blockquote>
Don't do this
