Should I?
-Brent
In- line fuel pump (just in case the stock one won't handle it)
Ramchargers timing tuner (allows you to retard timing only when the n2o is activated- without messing up my custom pcm tune, also has a built in window switch so I don't engage it at a low RPM, and so it shuts off just before the shift and saves the trans).
Bottle heater (nice consistent bottle pressure)
Purge (makes sure no air in line so that the car won't bog from more fuel without more n2o)
Fuel pressure safety switch- kills spray if fuel pressure drops.
Colder plugs- prevent detonation.
In addition, I plan running 100 octane minimum when spraying to help prevent detonation.
