Stall size with nitrous?
Thanks charlie
For the size shot you are wanting to run something in the 3600-4000 range is probably where you will end up.
Call Greg@FTI or PTC and get a stall worked out for your combo.
Thanks charlie
Thanks charlie
I run a Yank PY3600....
and right now its just a .020 and a .024 set of jets...(8 jets each stage.... direct port...roughly 350 going into the motor)
I had the converter built to be a 5k stall...and I dont have any issues with it...its the same on motor and on nitrous...
with nitrous you need something that is a smaller than stock diameter and it needs to have anti ballooning plates, or better yet, be a hardened billet case
actual stall rpm is dependent on your setup and what your goals are...
if its street driven, you may want something down in the 3200 range
if its a track only car, you want to find something that fits the power curve of your engine for all out speed...
if it does both... then you need to find a happy medium, or atleast figure out what you feel like you can deal with on a regular basis
it gets pricey quick.... but dont let that sway your decision...
save up and spend some coin and get a good one...
Lots of choices....take your time.
