How much timing are you running?
It would have helped our old set up for sure though.
If you are running a jet limited class that allows Q16 it would be worth something, other than that I would not use it.
I think you guys took me to seriously on the perfect plugs thing. I just meant no signs of detonation.
Nice to see what some other people are doing though.
Keep it lean and low on timing and it will live forever.
JMO.
Rich and over timed is not the way to go.
We hurt some parts along the way to learn that and if they want to do the same its OK by me.
The objective is to use the least amount of timing possible while still making peak power. Not pushing it until it detonates and backing it off one.
The more you advance the timing the further away the piston is from TDC when the spark ignites. This effectively fights the piston's natural upwards motion by setting the spark off too soon and it actually hurts power and can detonate. By letting the piston use all of it's available momentum before it gets to the point where the spark is lit the less downward force your trying to exert on the upward moving piston therefore not fighting it near us much as with advancing the timing any more.
Honestly do what ATV said to do, put a bigger nitrous jet in it, you will make more power while still having a clean safe tune.
Keep the timing low and keep it lean on the AFR and it will live forever like ATVracr said. I would take his advice he has traveled a looong road on the LS nitrous train and is finally stepping off at Prochargerville, but still knows a thing or two
I believe we were at 17-18 degrees total from a base of 34 IIRC. I have to look at my XFI. This was using C16 and was a dry system. 83 lb injectors. 2 stage dry plate...
I was afraid and backed the time a few times to 26* and 32* and the engine didn't like it, so I went to 45 again.
Nobody believes me, but it's true. I even checked the timing and it's good.
For your new engine start with conservative timing, proceed with caution, check plugs and AFR, recheck every run until you feel safe to move timing and jets up.
I bet the guy with 45* timing's iron heads are playing a big part in the motor wanting that much timing. I've heard there is a big difference between what the two like(aluminum vs. iron)
Last time I changed head gaskets I even checked the zero timing mark against TDC and was correct.
Timing was checked with 3 timing lights and got the same readings.
It's crazy I know, but I haven't found an explanation why this engine likes so much timing.
side note...plugs looked better also
then some say go up and some go down. I agree with junkie why would you go up, but your lean comment surprised me. I know all engines are diff. but what do you like as far as a/f when spraying?
I have said many times I would never tell any one to start there but pretty much what ever it likes to be without nitrous is where it will make most power with it on.
I'll tell you what I tell most of the guys who PM me.
Where ever you think your timing should be start 3-4* below that and for A/F low 12's is where I would start.
Then get the fuel right on the plugs.
Add 1/2-1* at at time keeping an eye on the fuel as you do.
Trust the plugs.... The motor wants what it wants, there are no "set" numbers to use.... like you said every motor is different.
Hope this helps.... Good luck.
