Digital or Analog N20 Gauge? Which do you think would be better if I was putting it in the center vent on my TA? Analog: http://www.glowshiftdirect.com/produ..._NOS_Thumb.jpg or Digital: http://www.glowshiftdirect.com/produ...bs/Nitrous.jpg I like the look of the analog gauge (and that I set the color to red to match my other gauges), but I am concerned about the functionality of it. The useful range of pressure for N20 is just a narrow part of the needle's range whereas with the digital gauge N2O pressure is obvious. |
personal preference, id prefer the digital but thats just me |
I've never ran nitrous yet - what kind of resolution do you want from a gauge? Is seeing the needle is between 900 and 1,000 enough? That seems about what you'd get from the analog gauge... |
I think the digital would be easier to read |
Any other votes from people who use nitrous pressure gauges? |
It's all about the hardware, is it a sender and wiring, or running a line. I perfer the sender and wiring. |
Digital for a more precise measurment |
digital |
Originally Posted by socal
(Post 16244781)
digi i have a digi gauges, digi tach and than a autometer 2 3/8 tach cuz when theres bright sunlight you wont see the shift light. the track goto faces the sunset.... id only go analog for a situation like bright light, etc.... |
Digital if going with that style of gauge. |
Digital. :thumb: |
Originally Posted by Chris@NitroDaves
(Post 16248063)
Nitrous pressure has very little to do with actual nitrous left in your bottle.. On a 15lb bottle, I can get down to 4lbs if nitrous and still be able to get pressure up to 900 with a heater... 6 lbs is where I start to see an actual drop off that the heaters can't keep up with very well... On a cool day, my full 15lb bottle will read 750-800 until I heat it up... Gauge type should be preference... I use a digital gauge from holley because it directly interfaces with my holley dominator pcm.... Otherwise, I think I would have gone analog to match other gauges I had before the holley gauge swap I did for all my gauges. |
Originally Posted by 1quickTransAm
(Post 16248654)
As opposed to what style??? What is there other than needle and digital? Me personally i'm extremely partial to the Autometer Phantom II series of gauges. http://img818.imageshack.us/img818/8...dayvsnight.jpg |
Digital for sure , I installed mine on the left driver side vent https://fbcdn-sphotos-a.akamaihd.net...71199504_n.jpg |
I have an analog gauge on the bottle. My bottle sits in my passenger seat location(race car:)) so it's easy to read for me as it points right at me. I am building a switch plate now and it will have provisions for a digital nitrous and digital fuel pressure gauge. Just easier to read I would think. |
© 2024 MH Sub I, LLC dba Internet Brands
