Is your N2O gauge inaccurate?
Old Feb 20, 2002 | 07:18 PM
Country Boy's Avatar
Senior Member
Default Is your N2O gauge inaccurate?
I have the Autometer regular nitrous gauge in my gauge pod. Its hooked up right after the bottle nipple with my other N2O gauge that I got with the kit (inline gauge) and the my NX warmer control. When the inline gauge reads ~1000 psi, the gauge up front only reads ~800 psi <img src="images/icons/confused.gif" border="0"> Are they all this inaccurate? Which do I believe?
Old Feb 20, 2002 | 07:23 PM
383LQ4SS's Avatar
Default Re: Is your N2O gauge inaccurate?
They are pretty crappy gauges. Tap it and you will see the pressure jump up to near correct levels. I even returned the gauge and got a new one. But this one is the exact same. I wonder if the electronic gauges from NX express are more accurate?
Old Feb 20, 2002 | 07:26 PM
Senior Member
That was my next move also. I dont like how the gauge half hangs out of the pod because of the -4 line running up the pillar. I dont know why they give you a restrictor to put in the line also, but that probably half my problem because when I heat the bottle up to where the front gauge says 1000 psi, the bottle may be at 1200+ psi. Not good on a wet kit.
Old Feb 20, 2002 | 08:09 PM
Slowhawk's Avatar
LS1Tech Sponsor
Mines been accurate.Digital elctric gauge.
Here it is
www.speedshop.org
