NOS bottle heater and MSD window switch question
Old Feb 24, 2002 | 06:38 PM
horist's Avatar
Default NOS bottle heater and MSD window switch question
Hey all, i'm connecting my nitrous electronics this week and have a few questions:
Anyone have pics of the nos bottle heater install? I can't see to figure out how they want me to mount the temp sensors... also the instructions only show 1 sensor but it came with two.
Also, w/the MSD window switch it says to connect to negative on the ignition coil... does that mean I should just use the #1 cylinder coil pack and splice in with the black wire on it? (4 wires).
My car is a 2000 Trans Am .
Thanks,
Mike
Old Feb 24, 2002 | 11:30 PM
horist's Avatar
Default Re: NOS bottle heater and MSD window switch question
update:
what wire is the tach wire on the PCM?
Old Feb 25, 2002 | 11:50 PM
horist's Avatar
OK... i found that the #10 wire on second PCM unit is tach signal... so i have to tap into that.
I read that w/a MSD Tach light you have to cut the receiver so it thinks your running a 4 cyl (due to LS1 Ignition 2 pulses per revolution) does this apply to the window switch too? Should I cut the wires and make it think my car's a *shudder* 4 cylinder?
