Window AND WOT switch?
Old Mar 2, 2002 | 03:01 PM
Sears's Avatar
!Dial-up Director
Default Window AND WOT switch?
Will a window switch only activate @ WOT? Or do I need a WOT switch to accomplish this?
Thanks,
Justin
Old Mar 2, 2002 | 04:59 PM
ExtremeZ28's Avatar
Default Re: Window AND WOT switch?
i think if you didnt have a WOT switch but you had a window switch then it would spray anytime you were at say 3k-6k.....so im just assuming you would want both <img src="gr_stretch.gif" border="0"> just an assumption though <img src="gr_stretch.gif" border="0">
Old Mar 2, 2002 | 05:57 PM
Sears's Avatar
!Dial-up Director
That's what I was thinking too. <img src="gr_eek2.gif" border="0">
Old Mar 4, 2002 | 11:09 PM
Pete2k_Z28's Avatar
Yes, you should run both. Always wire nitrous saftey's in series, this way if one of the saftey's activates it will break the loop and disable the solenoids. For example, you would want your arming switch, WOT switch, and window switch to all be wired in a "loop" with the solenoid relay. So if you're at say 4500 RPM with the arming switch on, but only at 80% throttle, you could not spray, I think you get the idea.
Have fun <img src="gr_stretch.gif" border="0">
Pete
